Brake question
Old Mar 2, 2021 | 02:18 PM
Wesc233's Avatar
8th Gear
Default Brake question
Master cylinder was leaking! Changed the master cylinder, bled the brakes and reverse pressure bleed! Break pedal is really stiff and isn’t stopping very good! Checked the vacuum line and it’s working! What could be the issue? Thanks for the help!!!
Old Mar 2, 2021 | 02:46 PM
redwhitekat's Avatar
i think you have to power bleed the system you can do it with a proper disnostic tool or by making a switch and wiring to starter and remove fuel relay to power the abs system of that braking system
watch the videos on atlantic british or just search
Old Mar 2, 2021 | 02:50 PM
mollusc's Avatar
Brake pedal being very stiff and poor stopping power is classic vacuum leak. Check that your brake booster isn't leaking where it connects to the new master cylinder.
Old Mar 2, 2021 | 03:22 PM
whowa004's Avatar
power bleeding might be strongly suggested but is certainly not required in my experience. mollusc is on the right track with a vacuum leak.
Old Mar 2, 2021 | 04:03 PM
Op said he checked vaccum line and it was working
Old Mar 2, 2021 | 04:41 PM
mollusc's Avatar
Vacuum line is "working" is very vague. Doesn't mean that the booster isn't leaking. That's different from checking the vacuum line.
Old Mar 2, 2021 | 04:59 PM
Wesc233's Avatar
8th Gear
How do I check for a vacuum leak?
Old Mar 2, 2021 | 05:49 PM
Extinct's Avatar
Pull your MC out of the booster again, without disconnecting the brake lines. I bet your pushrod dropped down and is not pushing in the MC correctly.
smokey73
May 12, 2022 06:25 PM
bosshogt
Sep 2, 2020 10:35 PM
Hoots
Oct 30, 2016 04:55 PM
romulus prime
Mar 3, 2016 08:40 PM
drdeadchef
Jun 10, 2012 09:43 AM
