Brake question
Master cylinder was leaking! Changed the master cylinder, bled the brakes and reverse pressure bleed! Break pedal is really stiff and isn’t stopping very good! Checked the vacuum line and it’s working! What could be the issue? Thanks for the help!!!
i think you have to power bleed the system you can do it with a proper disnostic tool or by making a switch and wiring to starter and remove fuel relay to power the abs system of that braking system
watch the videos on atlantic british or just search
romulus prime
Mar 3, 2016 08:40 PM
