Brake question
Old Nov 12, 2008 | 12:36 AM
mwindth's Avatar
Default Brake question
What do you think is the cause of the brake pedal first going to the floor when depressed and if depressed suddenly again, tons of pressure hits the foot pedal and it stops the vehicle on a dime! Do they need to be bled?
Thanks again!
Old Nov 12, 2008 | 01:20 AM
CandiMan's Avatar
Default RE: Brake question
ORIGINAL: mwindth
Thanks again!
If the bleeding doesn't help then I would say master cylinder.
Old Nov 12, 2008 | 08:39 AM
discoxd's Avatar
i'm having somewhat the same issue... i bought new brake pads and plan to put them on this weekend when i install my lift kit... i will let you know if it helps...
________
Bondage Webcam
Old Nov 12, 2008 | 03:28 PM
Part of Rovers soft brake come from the rubber brake hoses at the caliper. When replaced with stainless steel, the pedal improves quite a bit as does the stopping, along with a full brake fluid change.
Old Nov 12, 2008 | 04:44 PM
mwindth's Avatar
Thanks Disco Mike...good idea.
Old Nov 12, 2008 | 11:36 PM
apcollin's Avatar
could be an air bubble in the line
SolAeon
Jul 10, 2012 09:05 AM
ctystrickland
Feb 15, 2011 07:54 PM
tibyABv6
Jan 7, 2011 06:02 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
