Brake Repair - pressure problem
Old Sep 7, 2024 | 04:19 PM
rappo999's Avatar
Default Brake Repair - pressure problem
Hi. Seeking some guidance please.
2001 Disco2 good shape generally.
Front left brake line corroded through near the flex line connection. Replaced hard line and flex line. All good. No leaks.
While messing with brakes figured I would replace master cylinder, it looked old and rusty, brakes were never great.
Installed and seems OK. Primed the new master cyl by loosening the 2 lines and stepping on pedal. Bled 4 corners with hand vac pump. Replaced bleed screws.
With the car off the brake pedal is solid and has good pressure. With car on, pedal is soft and goes to the floor. Brake light on. Any suggestions? Thank you in advance.
Old Sep 7, 2024 | 11:05 PM
mollusc's Avatar
You need to power bleed the ABS unit. Plenty of threads on here telling you to do it.
Old Sep 8, 2024 | 04:41 PM
rappo999's Avatar
Default All fixed.
Thank you.
Combo vac leak around new master cylinder and needed proper bleed. All sorted. Appreciate the help.
Old Sep 8, 2024 | 07:06 PM
Harvlr's Avatar
Great to hear!
Shaun1994
Sep 29, 2024 05:02 AM
MAF Diver
Jul 3, 2024 10:00 PM
Robert Tripp Norwood
Dec 28, 2022 02:19 AM
mxmom99
Sep 3, 2015 07:34 PM
holly254
Jul 11, 2008 07:21 AM
