Using CDL as interim fix
Old Dec 12, 2010 | 10:11 AM
jarrcr's Avatar
Default Using CDL as interim fix
The vehicle:
2000 Land Rover Discovery II
So the back story:
I rebuilt the front drive shaft, new u-joints, new centering ball. Its been about a month and I start hearing this chirping which then turned into a grinding noise. I removed the front driveshaft and engaged the CDL manually as I can't afford the linkage yet. Now the noises are gone. All the crosses look good but I think the centering ball is jacked. I haven't taken apart the driveshaft yet to look at the centering ball, that's probably the project for today.
The questions:
Can I drive for a while with no front driveshaft and the CDL engaged? It doesn't seem like there would be any issues. And if the housing is screwed up for the centering ball can I get just that piece of the shaft or do I have to buy an entire new shaft?
Old Dec 12, 2010 | 10:15 AM
Check your rear roto-flex for cracks between the 6 bolts, if it is OK, then yes as long as you don't do full throttle accelerations and make sure your rear u-joint is greased and OK.
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
lsmit605
May 11, 2011 11:50 AM
lipadj46
Feb 11, 2010 07:45 AM
mge_1
May 6, 2006 07:46 PM
