They are known to make noise. How glazed up are your rotors? Did you bleed the brakes after the brake job?
If it were mine I would rough up the rotor surface, clean them well and try some more brake sound deadening material.
Mike
I would take the truck over to the shop you bought the pads from and tell them you want to replace them cause they are noisey. Unfortunatly they are somewhat known to be noisey.
Mike
