Brake Squeal
Old Mar 15, 2007 | 07:26 PM
Aquaholic's Avatar
Default Brake Squeal
Put new Mintex pads on all around.
They're usually quiet - but...
Once you heat them up, ie lots of slowing down and turning in neighborhoods, they will squeal.
Any secret tricks? - I tried my ancient chinese formula (silicone on the back of the pads) but that didn't work.
Old Mar 15, 2007 | 07:50 PM
Default RE: Brake Squeal
They are known to make noise. How glazed up are your rotors? Did you bleed the brakes after the brake job?
If it were mine I would rough up the rotor surface, clean them well and try some more brake sound deadening material.
Mike
Old Mar 16, 2007 | 02:34 PM
Aquaholic's Avatar
I did rough up the rotor surface, and I changed to synthetic fluid - bleeding twice to be sure.
Any deadening material your favorite?
Old Mar 16, 2007 | 02:59 PM
I would take the truck over to the shop you bought the pads from and tell them you want to replace them cause they are noisey. Unfortunatly they are somewhat known to be noisey.
Mike
Old Mar 16, 2007 | 03:05 PM
Aquaholic's Avatar
Okay - Thanks.
Reminds me of a 1982 Mercedes I had - you just have to live with the brake noise.
Ben09
Dec 9, 2011 01:05 PM
PFS
Sep 5, 2011 02:01 PM
nickd503
Oct 3, 2010 10:00 AM
pipjack
Jun 10, 2010 01:18 PM
mike.howard
Jul 3, 2006 07:27 PM
