Brake switch?...
Old Mar 28, 2017 | 08:48 AM
jamestfl's Avatar
Default Brake switch?...
On Sunday I experienced the stuck in park situation. Took the shifter cover off and have been manually moving the shifter pin to change gears. Brake lights are also out. Read a few threads around this issue, but am still not clear on cause of issue. Does this sound like a broken brake light switch? Shifter pin in center of pic.
Old Mar 28, 2017 | 09:13 AM
Bom2oo2's Avatar
sounds like it, you can test it to make sure by pulling the pigtail from switch & jump the connection with a piece of wire to see if it will release the pin, if switch is problem you can get the genuine part from autozone for $12 or $13, and it the upgrade version, it says (made in Malta) or similar on box, but on switch it says Made in Germany,
Old Mar 28, 2017 | 11:34 AM
jamestfl's Avatar
thanks for that. Actually found one on Amazon, for delivery tomorrow. Preciate the confirmation.
Old Mar 28, 2017 | 02:26 PM
Best4x4's Avatar
Yep the Auto Zone switch is the
Genuine LR Updated unit.
Old Mar 29, 2017 | 07:01 PM
jamestfl's Avatar
(apologies for the double post- dont even know how I did that) new brake switch installed, got the old style asthma-inhaler looking one. brake lights working, no shifting issues. mission accomplished!...
shezm
Dec 28, 2015 11:25 PM
abran
Aug 5, 2014 06:13 PM
Rover Newbie
Jul 13, 2014 10:46 PM
AZRover
Jul 2, 2012 06:43 PM
tibyABv6
Jan 7, 2011 06:02 AM
