Brakes
Rear Rotor minimum thickness is 0.461 inches, front should be at least 0.866. Don't skimp on your brakes, you're stopping a heavy load and you'll want them to last. Akebono is a good brand, I've used them before, they give off a bit of brake dust when you first install but it goes away after a couple of hundred miles.
