Brakes Concern
Old Jun 2, 2012 | 05:34 PM
CANAMDiscovery's Avatar
Default Brakes Concern
When the brakes are applied the truck comes to a nice stop; however if I release my foot from the pedal while stopping and apply pressure a second time the power of the brakes almost doubles. (Or so it feels).
Is it a normal thing to need a "double pump" to get the full effects of the braking ability?
If not, what needs to be looked at?
I had a brand new ABS modulator put it in a couple years ago. ( to rid myself of the 3 amigos). System bled.
I have also installed new pads and rotors all the way around...almost a year ago.
The brake fluid level is good and can see no leaks.
I have felt this for a long time and was once told it was normal?
I assume that because of the strong braking on the second press that the system is not leaking.
I think I read somewhere here that replacing brake lines to a stainless, may help?
Any input always appreciated...
B
Old Jun 2, 2012 | 06:13 PM
What you are describing is normal for a D2.
If you want a firmer pedal, replace your rubber brake hoses to the calipers with stainless steel, makes a nice difference.
Old Jun 3, 2012 | 08:04 PM
Hey Mike,
So, was this designed into the Land Rover Discovery? Is there some off reading reason to have some softer brake pedal as I described?
Old Jun 3, 2012 | 10:09 PM
That is just the way they came from the factory.
Old Jun 4, 2012 | 06:54 AM
drowssap's Avatar
the good old "disco double step", mine went away when i replace my brake hoses.
FightOnUSC79
Nov 26, 2010 09:43 AM
llPANCHOll
May 16, 2009 09:46 PM
DeShawn
May 5, 2008 07:02 AM
jmrover
Oct 15, 2007 07:41 PM
ceomilord
Sep 16, 2007 04:07 PM
