Brakes pushing back during slow breaking
Old Sep 13, 2008 | 03:14 PM
  #21
Default RE: Brakes pushing back during slow breaking
You caould have warped rotors.
Pull the fuse to the ABS pump and see if the problem is still there.
Old Sep 14, 2008 | 12:38 AM
  #22
wizard's Avatar
I pulled the 40 amp abs fuse and went for a short drive and the brakes feel the same, so it appears the abs is ok. I will bleed the brakes and then look at the master cylinder. Thevacuum pump was replaced a few services ago so that should not be a problem.
Thanks for your advice
Wizard from Australia
Old Sep 14, 2008 | 09:39 AM
  #23
04BluDisco's Avatar
Speaking of ABS fuses, does anyones ABS block (top of drivers side front fender, next to PS fluid) make noises after the car is turned off? The noises are very quiet, and continue going regardless of how long the car has been turned off.... sounds a lot like the noises they give computers on TV when they give them personalities.... ala Tron in the 80's.... everything works just fine, more of just a curiosity...
Thanks
Jason
Old Sep 14, 2008 | 10:59 AM
  #24
04Blu-The pump is not supposed to run all night. maybe for a minute after you turn the truck off, but not all night. It will run your battery dead. You need to get it looked at.
Wizard-Replace your fuses and have your brakes looked at, you might have warped rotors. We have ruled out the ABS so that is where I would start next.
Old Sep 15, 2008 | 07:17 PM
  #25
wizard's Avatar
Spike555
Thanks again, ruling out the ABS has saved lots of money, will look at rotors.
Cheers
Wizard
Old Sep 15, 2008 | 07:41 PM
  #26
No problem. The ABS on DI's always goesbad when they get old and itis very easy torule out. And its a free place tostart.
aBs0lut30
Dec 22, 2011 12:18 PM
jonathanbucklew
Dec 1, 2010 07:42 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
XCELLER8
Aug 27, 2010 10:07 PM
TBW
Nov 24, 2007 07:19 PM
