Brakes and Rotors at 30K
Old Oct 21, 2006 | 07:10 PM
BuffaloRider's Avatar
4wd High
Default Brakes and Rotors at 30K
A used car dealer that sells Land Rovers is telling me that all Discoveries need new brakes and new rotors at 30,000 miles. Is he correct????[8D]
Old Oct 21, 2006 | 08:38 PM
Default RE: Brakes and Rotors at 30K
No he is not correct.
Rovers are a little weak in the brake area, it would b great if they used slightly larger rotors.
At 30K, it is possible you may need front pads, but as long as the truck has not been run hard you won't need rotors until the second or possibly third brake job.
Hope this helps.
Mike
Old Oct 21, 2006 | 09:17 PM
Elhoff's Avatar
Mine needed new rear pads and rotors at 33K. The previous owner had used it almost exclusively for commuting in stop and go freeway traffic. Got 70K out of the original front rotors. Now I have DBA rotors all around and the seem to be wearing very well.
Elliot
Old Oct 22, 2006 | 07:48 PM
sna77's Avatar
I just replaced all 4 pads and rotors at 30k miles... Pads were wearing and they suck anyhow, so figured I'd take the chance to upgrade...
Unfortunetley no respectable rotor company makes aftermarket rotors for a Disco, so I bought 4 rotors from the dealer, and then bought some AXXIS Ultimate brake pads. stopping power is gretaly improved, and the pads are basically no dust also...
Old Oct 22, 2006 | 07:59 PM
angasreid's Avatar
My 2004 Disco just hit 36,000 and I replaced both front and rear.
Old Oct 22, 2006 | 08:13 PM
ORIGINAL: sna77
If you drive your Rover anywhere like your BMW, they probably would wear out early. Too bad you didn't find any information about DBA slotted and drilled rotors, I have nearly 60K on mine along with the Kevlar pads.
There are choices out there.
Mike
Old Oct 22, 2006 | 11:54 PM
sna77's Avatar
I saw the DBA slotted rotors... I talked with a few brake experts, who convinced me that the best (and very limited oiptions) for the Disco were to just stick with stock for the rotors...
Oh, i could have gotten more life out of the rotors--the pads were kind of worn, so I figured itd be better to replace the rotors while I was doing the pad, as opposed to grinding them down...
But yeah, I don't drive the Rover anything like the 3... I'd flip it.
Old Oct 23, 2006 | 11:17 AM
Well, so much for the brake experts. When trying to find information on Rovers go to the Rover owners on the forums and see what they have been having the best luck with. DBA's hold up so much longer giving much better stopping power over Rover rotors.
By the way, you can not resurface Rover rotors, the material is too soft and there is not enough thickness to do the usuall 2 cuts to refinish them.
Mike
Old Oct 23, 2006 | 12:38 PM
sna77's Avatar
ORIGINAL: Disco Mike
Mike
I wish I'd known about these forums when we bought the Disco2 initially... Although other than the brakes i haven't had to do much to the car yet... In a few years I'll imagine that it will become much more useful as the car gets older and the warranty runs out...
BTW, the brake expert I spoke with was Dave Zeckhausen, from NJ: http://www.zeckhausen.com/ He was one of the original founders of UUC Motorwerks back in the day, and is pretty highly regarded... Anyhow, StopTech now makes rotors for the Disco which would be a nice replacement alternative
Old Oct 23, 2006 | 01:17 PM
DBA rotors out of Austriala have been the best rotor available for Rovers over the last 3 or 4 years especially when being used along with Kevlar pads.
Check out this web site, https://www.expeditionexchange.com/dba/
Mike
timrice
Off Topic
Jan 16, 2015 09:09 AM
tjp74
Nov 13, 2012 01:11 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
rolivier
Oct 5, 2008 03:16 PM
bigugly82
Aug 22, 2007 01:08 PM
