Bringing my AC back to life (questions on long-neglected AC revival)
Old May 19, 2020 | 02:23 PM
ahab's Avatar
Won't cycling from the compressor indicate that the switch is doing its job? Otherwise it would run forever. I'll do some investigation for sure. I recently jumped the switch to test the AUX fan and I don't remember any strange behavior then, and the switch worked fine in the old truck however anything is possible. Not exactly something I want to leave alone and simply hope everything is OK. AC is too important ;)
Rereading your clip from the manual, sounds like maybe my low side switch has failed.
Old May 19, 2020 | 02:30 PM
boston4's Avatar
Agreed that it's important - saves your window regulators too.
Cycling from the compressor would normally indicate that the switch is doing its job: to protect the compressor from either too low or too high of pressure - look at the table above. If the compressor kicked on while the system was empty, I'm thinking faulty pressure switch because the circuit was closed when it should have been open.
Old May 19, 2020 | 02:59 PM
ahab's Avatar
Well this just got weirder. I went to put a meter on the switch and found this. WTH??
Edit: OK, at least one riddle is solved. As I was typing the above it dawned on me that there could be a very simple solution to this so I went back out to check ...
Jesus, I'm a threat to the health and safety of others, I better turn in my mechanics license!!
Old May 19, 2020 | 07:22 PM
boston4's Avatar
Tough to see. Looks like the switch is jumped?
Old May 19, 2020 | 10:19 PM
ahab's Avatar
Nailed it.
Old May 19, 2020 | 10:23 PM
boston4's Avatar
Whelp. That’ll do it.
Old May 19, 2020 | 10:29 PM
ahab's Avatar
Yah, musta left that thing in there. Which on one level is good news since that means that no more troubleshooting required. On the whole other level however it sounds like I mighta fried a compressor due to my, ummm, oversight.
Old May 19, 2020 | 10:30 PM
boston4's Avatar
Originally Posted by boston4
Just trying to follow ... the compressor kicked on with no charge because the pressure switch was still jumped from previous troubleshooting, so the compressor ran with no refrigerant or oil?
I called it though
Old May 19, 2020 | 10:35 PM
ahab's Avatar
Yep. I owe you one. I'm sure I would've figured it out when I swapped the drier and reconnected the line prior to charging the system, however who knows how much time I would've wasted troubleshooting the circuitry had you not got me thinking.
landroverdude
Mar 26, 2020 07:20 AM
rovingaz Ryan
Sep 9, 2019 01:47 PM
DieHard
Jul 14, 2017 09:19 AM
Bishop
Aug 15, 2015 11:31 AM
scottmb23
Aug 17, 2013 08:23 PM
