Discovery 200TDI, Rear Axle /Diff, Noise and play of Half shaft one side Only
Old May 24, 2006 | 07:44 PM
DiRanged Rover's Avatar
4th Gear
Default Discovery 200TDI, Rear Axle /Diff, Noise and play of Half shaft one side Only
Hi all,
I have a problem with the rear axle , axle covered about 175,000miles
Lots of play on on near side Rear wheel, ( its not the wheel wobble you get from wheel bearing )
Its rotational play , about 3-4 inches before diff takes up,
Quite a bit of clicking , metalic noise from diff area,
The vehicle still drives Ok,
Yet the off side wheel there is minimal play....and no noise
I have not investigated any more than jacking wheels of ground,
I want to get some advice and be prepared.....
Any help and advice greatfully received, Thanks.........
Old May 24, 2006 | 10:39 PM
Default RE: Discovery 200TDI, Rear Axle /Diff, Noise and play of Half shaft one side Only
Sounds like you may be driving on a gernaded diff that is refusing to die.
May want to drain the oil and look for metal.
Mike
Old May 25, 2006 | 07:58 PM
4th Gear
What do you think the problem will be , Half shaft OR?
Any ideas,
What will the solution be ,
thanks
Old May 25, 2006 | 09:39 PM
You better drain the diff and inspect for metal, I still believ you blew your diff, not a axle problem.
Mike
Old May 26, 2006 | 12:18 AM
4th Gear
The Disco still drives and tows a car trailer fine,
Is it possible , that the vehicle can drive using the front wheels supplying the power..
Old May 26, 2006 | 12:39 PM
ORIGINAL: DiRanged Rover
I am amazed that you are still driving it with that sort of a potential problem facing you. Something is about to fail and the more you postpone checking it out, the worse $$$$$ it will be.
Get back to us when someone has had a chance to check it.
By the way, yes you can drive on the front diff if you lock your t/case.
Mike
xmarksit
Nov 26, 2013 08:37 AM
Aus-trek
Dec 31, 2012 07:56 PM
cationmoted
Oct 19, 2012 07:39 AM
ajh
Sep 9, 2007 06:36 PM
DiRanged Rover
May 24, 2006 07:36 PM
