broken fuel line
Old Jan 6, 2008 | 10:38 PM
armymp15's Avatar
6th Gear
Default broken fuel line
I need to know is there a fuel lne repair kit? When the drive shaft snapped it cut one of the fuel lines. It is that hard plastic line. Thanks
Old Jan 7, 2008 | 12:26 AM
spoon's Avatar
Default RE: broken fuel line
I wonder if you would be able to just replace that portion of the line with some rubber fuel hose. You can get that stuff from Autozone.
Old Jan 7, 2008 | 12:29 AM
armymp15's Avatar
6th Gear
It is a pressure line so im not sure. Thanks
Old Jan 7, 2008 | 12:42 AM
spoon's Avatar
There's that expensive GoodYear brand hose, with the poly inner lining thatwithstands upwards of 250psi. That might be the hose you are looking for, which should be available at your local Autozone.
Here's a link of the hose I am talking about. http://www.goodyearep.com/productsdetail.aspx?id=5250
HTH, -Justin
jclrd01
Jan 31, 2014 01:46 PM
DiscoRover007
Jun 28, 2012 04:28 PM
CANAMDiscovery
Apr 24, 2012 07:19 AM
JerrodSteph
Jun 12, 2011 06:04 PM
JumPeR04
Apr 7, 2011 09:52 PM
