broken glass everywhere...
Old Sep 8, 2019 | 08:39 AM
CollieRover's Avatar
Originally Posted by jamestfl
Great suggestions! Thanks so much. Looks like a much more doable project than I had thought. Appreciate the help.
Grab a cheap set of plastic panel tools so you don’t scratch the paint while getting the door card off.
Old Sep 8, 2019 | 06:58 PM
Brandon318's Avatar
Originally Posted by Best4x4
It's not a bad job at all. You remove the door panel, unbolt the window glass from the regulator, and then unbolt the black window frame from the door. You then lift it up and out. Depending on where you live you might find the frame a complete rusty mess. If so grab the entire window frame and the glass from the junk yard. Then you install the window glass into the door and bolt it back onto the regulator. Then carefully lower it (helps to have 2 people to make sure it doesn't bind up and catch on something). Then install the window frame assembly over the glass. The window will move a little to allow you to install it. Then bolt everything up, and adjust the window frame in slightly so it doesn't leak air/water.
I've done it many many times and it's not a bad job at all. With the glass and frame from a pick n pull type yard I'd expect you to walk out for 50-65.00 for everthing. Heck some places only charge 65.00 for the entire door!!! Which is a steal because you get everything!!!
Agreed. Did this the other day in the process of replacing the door lock actuator and I was astounded by how simple it was.
Old Sep 9, 2019 | 12:53 AM
No Doubt's Avatar
This window security film installs easily just like window tint, but it prevents bricks from easily breaking your new glass:
https://www.ebay.com/itm/WIDE-30-76C...GME2riP9v-6pag
Old Sep 21, 2019 | 03:45 PM
jamestfl's Avatar
Got a replacement window next day from Paul Grant- huge props to him for far exceeding expectations.
Having trouble with getting window frame off due to rusted and stripped bolts. How to get those out?
mooni
Oct 10, 2017 09:44 AM
kingsly
Nov 14, 2014 04:50 PM
DrozPrince
Nov 20, 2012 12:59 PM
berkshireross
Aug 10, 2011 12:04 PM
patrick m
Aug 1, 2011 11:17 PM
