Broken HSE
Old Apr 1, 2018 | 06:38 PM
Keeper514's Avatar
3rd Gear
Default Broken HSE
i have a D2 HSE 2003. It overheats with a load. And I mean like 20 seconds to redline. From what I gather that’s a hole in the block or blown head gasket. No water in the oil.
Thinking of cutting my losses with this one and getting a different one. What’s it worth as is? Parts. It’s in good condition otherwise or- am I overlooking something silly?
Old Apr 1, 2018 | 07:27 PM
Dave03S's Avatar
Rule out all of the silly stuff first. You are premature in your judgement.
Right off the bat I'd say if you are relying on the dash temp gauge you are lacking 90% of the info you need to make ANY decision.
Find out whats wrong first, then decide what to do.
Lots of answers but only after you do lots of reading on here.
Best of luck, but I doubt its as dire as you think.
Old Apr 1, 2018 | 08:44 PM
Keeper514's Avatar
3rd Gear
Default Overheat
not relying on my dashboard lol. He water spewing out of the engine compartment gave it away. It will idle fine. As soon as it goes into gear with a load it immediately overheated
Old Apr 1, 2018 | 08:49 PM
Best4x4's Avatar
Sounds like poor coolant flow to me, clogged radiator, stuck closed thermostat, bad fan clutch, or bad water pump. If it’s engine wise you’d smell fuel in the coolant, hoses would be rock hard, or your oil could look like a mocha latte.
Old Apr 1, 2018 | 10:15 PM
Twix's Avatar
It's probably all of the above. I'd start with a full cooling system overhaul.
Old Apr 2, 2018 | 04:24 PM
Extinct's Avatar
Pull the radiator - shove a waterhose in one end and check the flow out of the other end. If the radiator flows free, do the bypass thermostat mod with no thermostat. Also, O'Reilly has the exhaust gas/coolant tester available to use for free.
Good luck.
Old Apr 2, 2018 | 05:34 PM
Keeper514's Avatar
3rd Gear
Default I’ll try
I’ll try the radiator. I’ve changed the thermostat and tried to test for exhaust in the water but really inconclusive. Couldn’t get a good test. I was thinking about doing a chemical flush. I’ve been told land rovers are pretty touchy with coolant
Old Apr 2, 2018 | 05:37 PM
Dave03S's Avatar
They aren't touchy with coolant at all, unless of course you neglect it. Just make sure no leaks, no waterfalls, and no Dexcool.
Boxcars
LR4
Oct 8, 2024 01:35 PM
ICECREAMEATER
LR4
Jun 7, 2012 06:53 AM
akondor
Mar 12, 2010 05:37 PM
danohameed
Mar 8, 2010 03:54 PM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
