broken ujoint nightmare
They are not going to recall the double cardon. If I dont replace the timing belt on my Volvo and it breaks and destroys the engine are they going to recall that? NOT!!
If you read your owners manual there may be a service interval for the double cardon. Or if the trk was always serviced by a Rover mechanic he would know what to look for and tell you when it should be replaced.
Bottom line it is a stupid and flawed design. And no, a broken driveshaft will not catapult a car end over end.
i was driving my 1999 disco 2 (101,000 miles) approx 30 miles per hour on a city street with my two small children when i heard what i can only describe as an exploding noise under the hood. i pulled the car over to a parking lot and realized that even if i wanted to drive on i could not. when i pushed on the gas, the engine revved but i did not go anywhere. i was shaking all over, it obviously scared me and my kids. after i got a ride home, we had the truck towed to our local land rover mechanic and he said the u joint broke which in turn broke the drive shaft which in turn put a hole in the transmission. cost 4500. ouch. he said he has seen this many many times. my husband found a used transmission and a cheaper drive shaft which helped with the cost, but the repair still cost half what the truck is worth!
after reading on line, i see i am not alone in this issue. i am wondering how common this problem is and why has land rover not recalled this part? it is such a simple fix. it is infuriating to know that our repair could have been avoided with an inexpensive part. if you know what to look for in these forums, you can see that the ujoint should be replaced to avoid this very dangerous problem. i am so thankful i was at a place where i could pull over quickly and was not in heavy traffic. i have told all my friends who drive discos to get the ujoint replaced now, before it breaks causing major problems. i wish someone would have told me. i am a mom, and i bought the car because it seemed to me to be indestructable and the safest car for my family. after all the problems we've had, i am nervous to drive across town!
Wondering what ELSE I'll need to buy so fix the tranny and drive shaft besides u.joints and the tranny itself.
Have to admit the cardan is a crap design but at 100K it should have been rebuilt or replaced. Lack of zerks is a common feature of later vehicles (my '95 Pajero has all greasable joints everywhere) The problem is also lack of true fundamental maintenance by knowledgeable LR people or garages. Oil and filter changes don't replace routine maintenance on ALL systems and many opt for basic servicing to save money. There is another issue where people don't take recognition of warning signs and sounds as maybe they aren't mechanically minded and then drive on regardless and things then go bang and the bills are huge. Without maintenance every vehicle is destructible sooner or later. It's good on this occasion no-one was hurt and the end cost wasn't too bad.
Ask SuperSport to repost his photos of a driveshaft arrestor I'm sure he'll oblige.
My non-greasable shafted lasted 130k. I had it rebuilt then it failed after it was rebuilt (because the guy who rebuilt it sucks, though). THEN I bought a BPutah hd shaft; super beefy. They used the wrong c clips in the driveshaft causing the joints to bind. I went to a driveline shop to get a new Spicer joint for my shaft and they gave me a non greasable joint, I did switch it for a greasable joint, but they swore that it was a far superior joint.
Done the new rear air springs though
shooler
Mar 9, 2012 09:49 PM
