Ujoint advice
Old Feb 6, 2011 | 10:59 PM
Rover Chris's Avatar
Default Ujoint advice
OK I am going to replace the u joint on the rear axle this week as I think my clicking may be coming from that, I did both the front drive shaft u joints about 6 months back and removed the drive shaft to do it, my question is has anyone done one with the drive shaft still on the truck? I am just wondering if it is worth taking it out for easier work or just easier to do it on my back under the truck? I suppose I could unbolt the rotoflex first then remove just the 2 caps of the u joint to take the shaft out that way, just looking for personal experiences.
Old Feb 6, 2011 | 11:48 PM
antichrist's Avatar
I'd remove it. I'd not to want to replace a u-joint without removing the propshaft.
Old Feb 7, 2011 | 09:31 AM
Make sure you grease them 1 to 2 times a year depending on your driving.
Old Feb 7, 2011 | 09:37 AM
well that's why the rear needs to be replaced, It doesn't even have a grease zerk in it!
Old Feb 7, 2011 | 09:39 AM
antichrist's Avatar
Spicer's service interval is every 5,000 miles for normal service, not "1 to 2 times a year".
Old Feb 7, 2011 | 10:00 AM
I lube everything each oil change, well everything but that back U joint but that's going to change with my shiny new u joint!
Old Feb 7, 2011 | 01:17 PM
antichrist's Avatar
Yeah, I do it every oil change as well. There's absolutely no harm in doing it more often and it's easier to remember just doing it every oil change.
Jared9220
May 24, 2014 03:41 PM
doomed
Apr 25, 2014 06:38 PM
sorbet35
Apr 22, 2012 08:24 PM
shooler
Mar 9, 2012 09:49 PM
fj60disco
Apr 20, 2011 06:14 PM
