Broken Wheel Studs And a Suprise
Old May 1, 2010 | 05:39 PM
FLRover's Avatar
4wd High
Default Broken Wheel Studs And a Suprise
Hi everyone,
I have been a member for a few months and now need advice.
I have a 04 Discovery with 73,000 miles, I have had it for a year and love it.
(yea I know it is a sickness, I have a bunch of British stuff in my garage)
I have two broken wheel studs on the left rear.
I just looked on line to order wheel studs and discovered I need to get the entire hub .
Now the questions....
1: Is this for Real?
2: Is there a good place to get a hub?
3: Should I look for used? (I have had good luck with "The Car Cannibal in Oklahoma)
4: Is there any "tar pits" I should be aware of when doing this job"
I have down loaded the manual.
Thanks in advance for the time and help.
Cheers,
Tom
Old May 1, 2010 | 06:18 PM
lipadj46's Avatar
New hubs are expensive but will tillery, paul grant, justin at lucky 8 all will have low mileage hubs. I'm sure you could replace the studs though if have the know how. Replacing a hub is easy urban panzer has a walk through on his site.
Old May 1, 2010 | 06:20 PM
How the hell did you break one?
Make sure to use a little grease on the threads before reinstalling the lug nuts.
Old May 1, 2010 | 06:31 PM
FLRover's Avatar
4wd High
Hi Mike,
I did a brake job a month ago and a made sure and tightened all the lug nuts with a torque wrench to the proper spec. However I did not grease them.
I have put on 1000 miles since the brake job.
will the lack of grease call this failure?
Old May 1, 2010 | 08:19 PM
Mrmerlin's Avatar
its a good idea to put some antiseize on the threads of the lugs so they dont seize
Old May 2, 2010 | 07:34 AM
Possibly especially if you over torque above the 103 spec's.
thehun
Aug 19, 2011 06:28 PM
geek_IM
Jan 10, 2011 09:49 AM
Greg Duncan
Aug 17, 2009 03:26 PM
okdiscoguy
Jul 9, 2007 10:49 AM
raid13
May 13, 2007 12:13 PM
