Burned Valve...what next?
Old Sep 25, 2017 | 12:41 PM
ElVerde's Avatar
Default Burned Valve...what next?
I'm pretty sure my '03 burned a valve. Truck started vibrating just a little at idle, and then on my way home the CEL came on.
Compression test shows very low compression in cylinder 3, so my hunch is a bad/burned valve or some other valvetrain issue.
My mechanic is going to pull the head and take a look....anything else I should have done/have him check while it's off?
The engine was rebuilt ~20k miles ago and I had the intake manifold gasket replaced (was leaking) about 100 miles ago....it just seems like dumb bad luck that this happened now.
Old Sep 25, 2017 | 02:07 PM
Jeff Blake's Avatar
I'd do the compression test again, this time adding a teaspoon of oil into the cylinder. If the results improve, then its likely the rings. If not, valves.
Old Sep 25, 2017 | 02:11 PM
ElVerde's Avatar
I had considered that too. Either way, we have to pull the heads, right?
Old Sep 25, 2017 | 02:12 PM
Jeff Blake's Avatar
Well you want to do the compression test with the heads on
Old Sep 25, 2017 | 02:18 PM
ElVerde's Avatar
You don't say....
Old Sep 25, 2017 | 02:27 PM
Jeff Blake's Avatar
Just making sure we're on the same page Yeah the heads will need to come off, after you figure out whether its the valve or piston rings.
What are the engine codes? are you burning oil?
Speaking of...I need to do a compression test myself...
Old Sep 25, 2017 | 03:02 PM
ElVerde's Avatar
Engine code was just for a misfire...nothing else. No overheating, no burning oil.
Old Sep 25, 2017 | 03:25 PM
No Doubt's Avatar
Borescope inserted through spark plug hole to verify?
Old Feb 20, 2021 | 07:33 PM
Extinct's Avatar
If you need a place to work on it, consider renting a self storage area large enough to fit the truck in, and an overhead light. You can remove the bulb and plug in an outlet adapter and plug in Halogen lights that will give off plenty of heat to work even in the coldest winter.
Good luck.
Old Feb 21, 2021 | 03:20 AM
The Deputy's Avatar
Think ELVerda is long gone, checked his activity and he hasn't been heard from since about a month after this post/topic.
CollieRover
Feb 20, 2021 05:10 PM
twaszak
Nov 30, 2010 08:06 PM
blast20
Jul 18, 2010 03:51 AM
1stevereynolds
May 20, 2009 01:26 PM
Erik
Jun 17, 2007 11:59 AM
