burning smell at rear well
Old Oct 21, 2008 | 10:48 PM
RamblingMan's Avatar
Default burning smell at rear well
Hello,
I've got a '94 disco, 97k. When I drive for about 1 hour or 15 miles, there is a burning smell not from the left rear tire. I'm sure of that much. What are the possibilities? The rotors have to be replaced and have lips which could be rubbing the caliper but that wouldn't really smell, it would be a grinding sound (happened to the front wheel). Any ideas?
Thanks, RM
Old Oct 22, 2008 | 07:03 AM
Default RE: burning smell at rear well
It take you a hour to drive 15 miles? Where do you live?
You say it IS coming from the rear tire or is NOT coming from the tire area?
Old Oct 22, 2008 | 07:52 AM
You most likely have a caliper that is stuick, not releasing the brake pads and overheating.
Old Oct 22, 2008 | 08:15 AM
discoxd's Avatar
what type of a burning smell? burning rubber? burning electricals? burning rat nest too close to your exhaust? (happened on an old sports car i had) is there smoke involved? try to narrow it down a little...
________
grandma Cam
Old Oct 22, 2008 | 11:53 PM
Sorry for the confusing post. The smell comes up at the left rear well when I drive 15 miles (stop and go) or for an hour on the highway. It doesn't smell like rubber or electrical burning. Its a different burn smell. Maybe brake pad as Discomike said. Gonna check that today.
RM
Old Oct 23, 2008 | 02:01 AM
tacomatech's Avatar
Does it seem to lack power and/or use more fuel? If it does, then there probably is a sticking caliper piston.
andrew12159
Jan 27, 2010 10:31 PM
bangkuaidiscovery04
Sep 25, 2009 11:08 AM
schowell
Jan 27, 2008 07:51 AM
nitim
Sep 16, 2007 09:36 PM
rebooTT
Nov 13, 2006 10:04 PM
