Buy and Build advice for a D2
Old Aug 2, 2018 | 07:21 PM
WeekendWarriors87's Avatar
Originally Posted by escott16
I’m investing in an ultra gauge soon for my 03, check it out. UltraGauge OBDII Scan tool & Information Center
thanks ive looked at those, way cleaner looking than a bunch on analog gauges on the dash
Old Aug 2, 2018 | 08:47 PM
Extinct's Avatar
Once you find what you're looking for...check the frame over thoroughly...especially behind the rear axle. Also, test drive for several miles, bringing it up to temp...and listening for any strange ticks, knocks, tapping, etc, etc. Look it over very closely underneath and under the hood, check all fluid levels, bring a code checker with you and make sure all lights appear when you first turn the ignition key.
There is a noticable difference between the 4.0 and 4.6...power wise...and some say reliability. Biggest factor is finding a rig that previous owner(s) have kept up on maintenance and repairs.
Thought l saw a nice 99 for sale here the other day, it was a lot of rover for the money...but l'm not seeing it now.
Good luck, with your search.
Brian.
I have 4, cannot feel the difference in power between 4.6 and 4.0, but I can vouch that the 03+ are the only ones I have ever had with slipped cylinder liners.
Here is the truck your were referencing for sale:
https://lynchburg.craigslist.org/cto...656330061.html
Old Aug 2, 2018 | 09:03 PM
2nd on the por15
You painted the exhaust?
Old Aug 2, 2018 | 09:15 PM
escott16's Avatar
Por15 hi-temp exhaust paint, been almost 2 years summer and winter with road salt in Pennsylvania , looks as good as the day I put it on
Old Aug 2, 2018 | 09:19 PM
Best4x4's Avatar
You will feel the HP difference after you modify a 4.0L, D2 but I’ve had excellent results with 4.0’s vs 4.6L’s in 03-04 D2’s.
Old Aug 2, 2018 | 09:22 PM
No kidding would have figured the cats would have cooked that stuff off in minutes.
Old Aug 2, 2018 | 09:31 PM
escott16's Avatar
It did on my other car but I made sure I did really good prep work, any good paint made for headers would suffice as well
Old Aug 2, 2018 | 09:56 PM
User's Avatar
I must say, my least problematic Land Rover EVER has been my 02 4.0. It has about 200k miles on it, and it doesn't make one strange noise. Original everything, including driveshaft but with rebuild Moog u-joints. Its had 1 head gasket in its life, and not much more than that. Runs 183F anything over 15MPH, and 194-195 idling. Original cooling fans, with Britpart 180F thermostat.
Old Aug 3, 2018 | 06:10 AM
thanks! funny how everyone says to get an 04 on some forums
Old Aug 3, 2018 | 06:12 AM
sounds like most of you guys are in agreement that the 4.0 is more reliable, sounds like id be best off with an 00 or 01 then add the CDL linkage or just crawl underneath with a wrench for 4x4. lots of 02s for sale in my area but as far as i know they dont have the CDL
