Buy whole Drag link or just ends?
Old Aug 29, 2022 | 12:39 PM
biggreen96's Avatar
Default Buy whole Drag link or just ends?
Ok time to tackle my front end slop! Can the 4 ends just be replaced? Or do I need to purchase the 2 whole links? It looks link maybe one end is welded on... I'd crawl under and look but the car is 20 miles away!
Old Aug 29, 2022 | 12:53 PM
Striker223's Avatar
You would need to buy both ends/the entire link from the look of what you sent
Old Aug 29, 2022 | 01:24 PM
jastutte's Avatar
you can just purchase the tie rod ends and replace those. they all thread in.
ignore this post. Brandon318 is correct.
Old Aug 29, 2022 | 01:54 PM
biggreen96's Avatar
Right on. So 3 with right hand threads (at knuckles) and 1 left hand thread. (at pitman arm)
Also, I see on rock auto there is a "SD" model listed. Does that cover my Disco II? Thanks for helping a noob!
Old Aug 29, 2022 | 02:45 PM
Brandon318's Avatar
No, not all the rod ends are replaceable. You have to order a new drag link if you want to replace both. I would consider getting the TerraFirma heavy duty steering rods instead (https://amzn.to/3AQJJVN) so you can replace both ends in the future. The rod ends on the TF kit are Defender ball joints, so if/when you order replacements in the future, you'll want to make sure you order those, not Disco 2 ends. The Defender rod ends have much beefier shanks.
Old Aug 29, 2022 | 04:07 PM
jastutte's Avatar
this is correct information. my post was not.
and I second the Terra Firma Heavy Duty rods. I have those on my '04.
Old Aug 29, 2022 | 05:03 PM
biggreen96's Avatar
Copy that! Thanks guys.
Old Aug 29, 2022 | 05:29 PM
Karmakannon's Avatar
I was in this exact position last week. I got the tera firma steering kit for just under $200. I was able to replace the worst tie rod end to get me by for a day trip while I was waiting for the steering kit to arrive. Even though half are replaceable, the one I did was pretty seized and required soaking for days, a bunch of heat, and a breaker bar.
The tera firma looks nice and is about twice as heavy as the stock stuff.
Old Aug 31, 2022 | 12:45 PM
nashvegas's Avatar
In theory on some of them you can replace the end joints; however, it's not worth it -- just replace the whole assembly with new joints at either end! (also some are not removable.. I am pretty sure the original ones from LR were removable...)
archaeology_student
Aug 11, 2014 03:00 PM
jalodge
Oct 6, 2013 11:00 AM
ebg18t
Apr 25, 2012 08:18 PM
jrm123180
Feb 16, 2012 09:08 AM
bantham1
Oct 28, 2010 04:12 PM
