Steering Replacement
Old Oct 5, 2013 | 11:16 AM
jalodge's Avatar
Default Steering Replacement
My D2 has some play in the steering wheel and likes to drift back and forth while going down the road. I was going to replace the tie rod ends but I don't know what parts to get. I looked at the diagram on Rovers North and it looks like there are just ball joints on the end of the track rod and drag link. Is this what I need to replace?
Old Oct 5, 2013 | 03:07 PM
kenk's Avatar
Your partially right. The drag link and track rod both have one replaceable joint end, one non-replaceable crimped-in rod end. If the crimped-end is bad, you have to get a whole new rod.
Land Rover Discovery 2 II Steering Bar Drag Link QHG000050 New | eBay
Old Oct 5, 2013 | 03:13 PM
kenk's Avatar
If it is the replaceable end, this is all you need:
Land Rover Discovery 2 II Range P38 Arm Drag Link Tie Rod New | eBay
Old Oct 5, 2013 | 03:49 PM
jalodge's Avatar
With 190k miles on it would it be better to just buy one of these?
Land Rover Discovery 2 HD Steering Drag Link Track Tie Rod End Bar Set X2 New | eBay
http://landroverparts.roversnorth.co...VERY-II&key=it
Old Oct 5, 2013 | 09:32 PM
XCELLER8's Avatar
yup, replace the drag link as well as the tracking rod
Old Oct 5, 2013 | 10:26 PM
jalodge's Avatar
I was looking on Rovers North and found the Heavy Duty Rods for $200 (STEERING ROD SET HEAVY DUTY DISCOVERY II PLS006HD, TF255 - Rovers North - Classic Land Rover Parts) and the regular replacements for $150 for the drag link (DRAG LINK ASSEMBLY LHD DISCOVERY II, QHG000050,RNH138, PLH138 - Rovers North - Classic Land Rover Parts) and $70 for the track rod (TRACK ROD ASSEMBLY DISCOVERY II, TIQ000010,RNH072, PLH072 - Rovers North - Classic Land Rover Parts). It seams as if the heavy duty ones are better but they are cheaper. Has anyone had any experience with either?
Old Oct 5, 2013 | 11:11 PM
FlyingZebra34's Avatar
After having to replace several track rods from rock rash I found the HD replacements are well worth it. The walls on the OEM parts are very thing and weak.
Old Oct 6, 2013 | 07:05 AM
jalodge's Avatar
Is there any reason why the HD are cheaper?
Old Oct 6, 2013 | 08:50 AM
ZGPhoto's Avatar
Kits are generally always cheaper, we buy the whole HD kit as one piece rather than putting it together. I run it on my truck and I agree, it is definitely worth it. Stock replacement is hollow DOM and doesn't let you replace singular ball joints.
Old Oct 6, 2013 | 11:00 AM
jalodge's Avatar
Thanks guys. It looks like I am going to order the HD kit.
bennyb43
Nov 28, 2015 04:01 PM
texci77
Jun 6, 2012 01:24 PM
PITTDISCO
Mar 18, 2010 03:07 PM
Granite Disco
Feb 28, 2009 06:48 PM
bklahl
Feb 27, 2009 02:35 PM
