A/C blower troubleshooting help...
Old Aug 22, 2015 | 05:01 PM
june82000's Avatar
Check the blower motor resistor. Too many wire colors...
Old Aug 22, 2015 | 05:44 PM
Clockwork John's Avatar
From what I've read, the blowet would work on max if it were the resistor, and the max setting bypasses the resistor. It doesn't work on any setting.
Old Aug 23, 2015 | 04:55 AM
Daedrix's Avatar
Banned
I dont know anyone who successfully fixed the main sorce of the problem. For myself, the work around has been working for over a year now with no problems. You might have to go that rout if you or no one else finds a solution.
Old Aug 23, 2015 | 06:46 PM
PalmettoDisco's Avatar
The passenger area fuse block is usually the problem and if so, you need to bypass it like I mentioned in the link I provided earlier, or get another fuse block. There is probably a cracked solder between connectors on the back and fuses on the front. Typically fuse hot side will read 12V but under load the crack cannot supply adequate amperage.
aguison
Nov 8, 2012 06:18 AM
fuze-17
Sep 9, 2011 02:24 PM
88Mwife
Aug 21, 2011 08:06 AM
DiscoIIBrandon
Jul 13, 2011 09:25 PM
lipadj46
Dec 15, 2009 07:52 PM
