A/C Blowing out of defrost?
Old Aug 11, 2013 | 02:59 PM
Extinct's Avatar
Wow! that is very helpful!! Thanks very much - although I must confess I am having trouble orienting to what I am seeing (I've never had my dash that far apart) - could you zoom out a bit and take another pic so we can clearly orient ourselves to your photo?
Originally Posted by ralphobell
As you can see by the attached pics, there is no way not to get A/C coming out the defrost unless you cover those sections where the light is shinning in.
Old Aug 11, 2013 | 09:23 PM
ralphobell's Avatar
I don't have any other pictures at this time but maybe these marked up will help.
Attached Thumbnails  A/C Blowing out of defrost?-lr-dash.jpg    A/C Blowing out of defrost?-lr-ac-vent.jpg
Old Aug 11, 2013 | 09:30 PM
ralphobell's Avatar
Sorry those did not turn out as big as I thought they would.
Old Aug 13, 2013 | 08:44 PM
Extinct's Avatar
Thanks for the clarifying photos, they have me wondering though if it could be made to work correctly by attaching an extension to the end of the current diverter door - based on what you have seen in there what do you think?
Old Aug 13, 2013 | 09:20 PM
ralphobell's Avatar
I don't think you could. As mentioned earlier your best bet would probably be a sweatshirt or one of those things you put in front of your house door to block the draft of air.
Old Aug 2, 2016 | 05:57 PM
keoni004's Avatar
Old thread, but still helpful. Some random flat black piece of plastic dash fell into the windshield black hole a few weeks ago and it's been blowing cold air out the defrost on the right all week. About to shove a towel in that gap...
Old Aug 2, 2016 | 06:10 PM
Best4x4's Avatar
All the D1/D2's I've ever owned did this. When I had my dash apart I saw the gaps in the flaps, and left it alone.
Old Aug 4, 2018 | 06:25 PM
GAG's Avatar
GAG
6th Gear
"As you can see by the attached pics, there is no way not to get A/C coming out the defrost unless you cover those sections where the light is shinning in."
I was researching the same issue on a 1999 DII. Slight A/C airflow out of the right defroster duct causing condensation during high humidity although little or no airflow out of the left. Defroster actuation seems to work properly as airflow is balanced and full force when defrost selected. No fault codes during self-test of AC/Heater control head.
I guess the fact that airflow on the right is present versus very little on the left is just characteristic with the circulation given the vent holes that are present?
Thank you.
Disco3JR
May 13, 2016 06:56 PM
Street Wolf
Oct 7, 2011 12:36 PM
JavaDiscoII
May 16, 2010 03:34 PM
ggushee
Mar 31, 2007 11:58 AM
PAXPAY
Aug 16, 2006 12:26 AM
