A/C Charging Question
Old Jul 22, 2010 | 08:40 PM
Rovin4life's Avatar
funny, just did a recharge on a range rover where a tech from another shop put in 4.9 lbs. Not 49 ounces. Apparently he thought 10 ounces equals one pound. The vehicle wasn't all that cold. But after putting in the equivalent of 3.1 lbs it ran nice and cold.
One thing we do in the shop is to vacuum out the moisture for a half an hour. Then add one ounce of dye and fill it up.
Oh and check for leaks right around the front where the line goes into the front grill. hard to see but look for oil leaks.
Old Jul 22, 2010 | 10:28 PM
SDinDS's Avatar
Originally Posted by 'BamaBoy
Thanks Eric, I will do a search on google for the pressures. I was unaware of the over-oiling. I put in 6oz which is what it called for. However, I'm glad to know this because I was tempted to add more oil to it (i'm glad i didn't )
I didin't replace the drier, should have I? This is my first "non-beater" vehicle, so i'm learning new stuff every day
I usually replace the drier if the system has been opened. Probably not a "late model" vehicle, but definitely on an older car. As long as you pulled a good vacuum on it then you should be ok.
Old Jul 23, 2010 | 11:51 AM
'BamaBoy's Avatar
Hahahah, I bet that a/c wasn't running to swell with 4.9 lbs in it
Thanks for the info, I'll check around the front today to see if I have any leaks. I put in some flourescent dye, so hopefully it will show up if there's any leaks
Mark G
Oct 29, 2012 09:02 PM
steve
Feb 18, 2009 12:02 AM
bonedoc
Jun 13, 2007 03:24 PM
sabsr1954
Oct 24, 2006 04:25 PM
RTLimo
Aug 15, 2005 12:42 AM
