A/C Clutch replacement
Old Aug 12, 2016 | 03:45 PM
CollieRover's Avatar
Default A/C Clutch replacement
My A/C clutch has gone intermittent at high temperatures. I had my mechanic check it out who had fixed a couple of electrical problems within the A/C system.
Has anyone swapped out just the A/C Clutch? There is a kit on ebay.
Old Aug 12, 2016 | 04:01 PM
disc oh no's Avatar
It's a pretty simple job. Usually you can get away without opening the system.
Old Aug 12, 2016 | 04:32 PM
Did you need a bearing press?
Old Aug 12, 2016 | 04:55 PM
number9's Avatar
New AC clutch should include new pulley with bearing installed.
Absolutely no reason to open system.
Old Aug 12, 2016 | 05:25 PM
disc oh no's Avatar
Like number9 said, the pulley should come with a bearing installed. The pulley assembly is usually held on by a snap ring. Sometimes you have to use a puller to get the pulley off. Just be careful not to damage the compressor shaft. It should be okay, just keep it in mind while removing and reinstalling the pulley. Other than that, there's not much to it.
Old Aug 12, 2016 | 05:29 PM
Thanks guys. I am going to order one.
Did you guys have a weird growl, or vibration when yours went bad?
Old Aug 12, 2016 | 05:59 PM
disc oh no's Avatar
They go bad all different ways. Sometimes they just stop working, the shims can wear out, the bearings can go bad, etc.
If it's got a grumbling sound in it, the bearing is probably shot.
I had a bearing actually fall apart on one of my other cars. The pulley was off center when I looked at it. It didn't fall off because it's sandwiched between the compressor and the clutch hub. That made some serious noise!
Old Aug 12, 2016 | 08:43 PM
number9's Avatar
Not the one I replaced. Bearing seized, shredded belt and stalled engine. Best not to depend on D2 until fixed.
Old Aug 22, 2016 | 07:33 AM
I did the A/c clutch repair. My kit did not come with a new pulley so had to press the old bearing out with a hammer, and socket. I did not have snap ring pliers so had to get some, but not a terribly hard job with the right tools.
The old one was obviously the original and very dirty. The bearing was fine. A/C did seem to be running a bit better.
However, at the end of the test drive the A/C goes intermittent, shutting the compressor on and off. I am going to test the temperature sensor in the cabin. I can't think what else may be telling the system not to work.
Old Aug 22, 2016 | 01:59 PM
squirt's Avatar
What do your running pressures look like? (High/low) Overcharge on the system can cause intermittent running at high temp.
Spike555
Jul 21, 2016 08:07 AM
buttocks
Dec 31, 2014 12:53 AM
JBoever
Mar 9, 2012 01:05 PM
kenk
Jul 17, 2010 12:49 PM
