A/C Control Unit fails to store settings
Old Aug 24, 2012 | 02:16 PM
ralphobell's Avatar
Default A/C Control Unit fails to store settings
I recently had my stereo stolen out of my Disco. Ever since then my A/C control unit will not store the settings for the Fahrenheit to Celsius and does not remember the previous temperature and fan speed settings once power is turned off.
I have replaced the ECU with a spare I had and it is doing the exact same thing.
Anyone have a clue what could be causing the unit to not store it's settings?
Old Aug 24, 2012 | 06:26 PM
jfall's Avatar
There is going to be a battery keep alive wire which got cut during the
hasty removal of your radio.
I thought people could not be bothered to remove radios these days due to the code needed???
Check ALL the fuses. One may have blown when they were cutting multiple wires in a bundle rapidly..
IF they are cutting say 5 wires at a time, they go across a hot - and a ground and blow the fuse.
In fact --- I bet that is it!!!
They cut the radio harness with a big pair of wire cutters and blew the fuse
on the keep alive batt circuit.
I would suggest renting a garage or moving.
Old Aug 24, 2012 | 08:25 PM
Fuse 20 inside truck comes to mind.
Old Aug 24, 2012 | 11:25 PM
oilspotLR's Avatar
Was it a stock stereo??? I'm going to hit my head against the wall if it was... Sorry about all this.
Old Aug 28, 2012 | 03:20 PM
ralphobell's Avatar
No the stereo was a $600 Kenwood with builtin gps, xm radio, and bluetooth. It was installed by the previous owner.
I'll check the fuses and the wiring again. Thanks for the input.
Old Aug 28, 2012 | 04:03 PM
ralphobell's Avatar
Savanah and Jfall hit it right again. Fuse 20 was the culprit! Thanks guys!
Old Aug 28, 2012 | 05:46 PM
jfall's Avatar
Try to find an identical Kenwood on eBay.
Order it.
And, match the colors wire for wire.
And, you are back in business with the radio.
Old Aug 28, 2012 | 09:09 PM
ralphobell's Avatar
Order it.
I ended up putting in a $100 Kenwood with detachable faceplate and purchasing a separate gps & xm radio for half what the other kenwood would cost. Now I can take it all inside with me.
mln01
Dec 6, 2014 02:06 PM
Red_Liner740
May 5, 2013 05:40 PM
Classklown90
Audio/Visual Electronics
Dec 10, 2009 08:03 AM
kfx4001442
Apr 14, 2008 11:08 PM
parajumper
Feb 23, 2008 09:55 PM
