A/C drainage,,,
Old Nov 16, 2008 | 05:51 PM
sloppyjoe's Avatar
Default A/C drainage,,,
so as some of you know i was having a issue with my passenger floorboard getting damp. so today as i was changing the oil in the rover i found the little drainage tubes that drain the A/C. i swiped my finger across the passenger side drain and water immediately began to rush out of it. within a few minutes there was easily a quart of water on the floor. it tuned into a slow drip by the time i was finished with the oil swap.
later went to brunch and when i got back to the truck there was easily a saucer sized water spot under the A/C drain and it was dripping once every 3 seconds or so.
got home and parked the rig and within 20min there was another saucer sized spot of water.
is thing ever gonna stop??? NOTE,,,, i was not using the A/C or defroster. does that much water really back up in there? crap!!!
Old Nov 16, 2008 | 05:56 PM
Default RE: A/C drainage,,,
Well a spot on the ground will looklike morethan it actually is.
Old Nov 16, 2008 | 06:04 PM
sloppyjoe's Avatar
oh i know that,,,
but i am just surprised at how much fluid is in there all backed up.
its like my rig had blue *****,,,,
Old Nov 16, 2008 | 06:17 PM
There are two drains and I think that they hold 6 gals each.
Old Nov 16, 2008 | 06:49 PM
Disco2Guy's Avatar
There could have been some leftover in the piping. When I see two drips after getting home I know the drains are good. If it's been a week or so I'll take a look underneath. My problem is I usually think about it when I get home and everything is still hot.
Old Nov 16, 2008 | 07:46 PM
sloppyjoe's Avatar
a whole lot more came outta the passenger side vs. the driver side.
which might explain the wet passenger floor boards[8D]
Old Nov 16, 2008 | 10:49 PM
Luv2Disco's Avatar
The draininge tubes are bigger in diameter than you would think plus, they are quite long.
aarongregor
Dec 19, 2012 12:23 AM
donagh
Aug 8, 2006 10:21 PM
