A.c.e.
Look at power steering fluid reserve jug - if two caps, you have ACE.
See attached
And download the whole set for your truck, called the RAVE, it is a set of factory shop, electrical, and owner manuals. You'll also want to look in our tech section for rebuild info on the front drive shaft, which if factory stock is waiting to snap with no warning and spear a big hole in the transmission.
See attached
