A/C Evaporator Leak
Old Jun 17, 2016 | 09:46 AM
CollieRover's Avatar
Default A/C Evaporator Leak
I am going to have to dig in and look at the Evaporator. I am going to get some dye, so when I get it apart I can see the leak.
I have the RAVE and will follow the directions, and will be careful to label and keep everything tidy.
I am going to get some short screwdrivers, and I have panel separators. i do have tools to remove the stereo as well.
Any advice on tools or potential issues please let me know, if not keep me in your thoughts and prayers!
Old Jun 17, 2016 | 10:12 AM
I just did the A/C manual diagnostic check, and got codes 21 and 22 which are sunlight correction sensors. I am sure that has nothing to do with the leaks though. I have an SE7 I wonder if I even have that.
Old Jun 17, 2016 | 02:32 PM
DiscoBuckeye's Avatar
I got one of those codes and it was low on refrigerant
Old Jun 17, 2016 | 02:53 PM
Well, I just checked the pressure of the system, and it looks Ok. It appears I may have the waterfall sound and a bubble in cooling system.
Old Jun 18, 2016 | 05:02 PM
Externet's Avatar
I just did the A/C manual diagnostic check, and got codes 21 and 22 which are...
That is new for me. Can someone explain how to perform the airconditioner diagnostic and where to find an error list ?
Old Jun 18, 2016 | 06:55 PM
number9's Avatar
PDF of test below. Found in WM.
File Type: pdf
wardpower
LR2
Jan 30, 2020 11:52 PM
jrm123180
Aug 24, 2019 07:59 AM
pgoodrich
Aug 19, 2015 08:31 PM
rgrizzard
Mar 6, 2008 10:16 AM
javarover
Jun 5, 2007 08:48 AM
