A/C Fan Burned Out On Settings 3 and 4
Old Sep 10, 2009 | 09:19 PM
mjbarrett01's Avatar
5th Gear
Default A/C Fan Burned Out On Settings 3 and 4
I have a 97 Disco with the A/C fan not functioning on settings 3 and 4. At first they worked, but it would cut out only occasionaly. The problem got progressively worse until they quit all together. I disasembled the dash and discovered that the plug for the fan switch is burned out for the 3rd and 4th settings. My problem now is that I don't know how to find a replacement plug. Anyone know where to find one? Also, is it possible to clean the original plug and have it be safe/reliable?
Old Sep 11, 2009 | 07:46 AM
ljdiscovery's Avatar
wrecking yard, simple, easy and it is almost as fun as going to disneyland......Phil
Old Sep 11, 2009 | 07:49 AM
Besides the plug, you may find that your resistor pack may be bad, this is the most common fault for failing fan speeds since it regulates the speeds for you.
Old Sep 11, 2009 | 05:42 PM
www.roverlandparts.com
Old Sep 13, 2009 | 01:33 AM
96LRDISCOSE7's Avatar
4th Gear
I have the same problem as you do # 4 and 1 work for me, it also cuts out on me too, i figure the switch is just not making good contact anymore, I have figured out how to manipulate the switch till im ready to get a new one. Atlantic British Ltd. and calling your local LR dealer, I have always heard dealer is high dont mess with them, Well I blowing that B.S. out of the water because its not always true, my dealer here in Texas is around the same prices as A.B. so i use both of them good luck
Old Sep 25, 2009 | 05:49 PM
wick_60010's Avatar
Default '99 Series I with very similar problem...
My fan switch works on 1, but not on 2-4. How do I remove the "face plate" (for lack of a better description)? I don't see any screws anywhere, and don't want to just pull it off if that's not the way to take it apart! Thanks!
Old Sep 26, 2009 | 12:51 PM
tweakrover's Avatar
I had the same problem, the actual switch was not making good contact and it heated the tabs melting them. take the switch and pull it apart ant see if ant of the little peices have sliped out of place or if you have to bend the contact pads to make good contact. if nothing is completly broken and you can get it to slide through all 4 positions and make contact, put some dielectric grease in it, throw it together and your good.
mrg
Feb 8, 2011 07:51 AM
03discoman
Dec 17, 2009 09:36 AM
dismuke5
Nov 8, 2009 11:42 PM
99LRDisc
May 22, 2009 09:51 PM
VB_Rover
Jul 20, 2005 02:43 AM
