A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation
Old Dec 9, 2013 | 11:27 AM
  #51
SuperSport's Avatar
Default Update
Just an Update...
It's been almost a year, and still no noises from my fan. This appears to have lasted a while. I may do it again after the winter passes as preventative maintenance.
Old Dec 9, 2013 | 11:42 AM
  #52
Bob Loblaw's Avatar
Default Another update
It's been over 8 months for me, and all is quiet on the fan front. This is way better than dropping $400.
Old Dec 9, 2013 | 03:18 PM
  #53
dr. mordo's Avatar
Originally Posted by SuperSport
Just an Update...
This is a good point. It's easy enough to do that it's probly worth doing annually to reduce bearing wear.
Old Jan 23, 2014 | 09:15 PM
  #54
Janadi's Avatar
Hi Supersport.
Great write up,did my fan a few days ago and is now so quiet.
It is always good when a few hours work saves you $$$$$$$.
Many Thanks.
Old Jan 24, 2014 | 03:23 AM
  #55
SuperSport's Avatar
Originally Posted by Janadi
Hi Supersport.
Many Thanks.
Thank you, I'm all about saving Money if I can. I'm glad it worked for you.
Old Jan 29, 2014 | 08:14 PM
  #56
jalodge's Avatar
I took mine apart for a squeaking noise and found this. It looks (and smells) like whatever this piece is melted through. Is this repairable or do I need a new one?
Attached Thumbnails A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation-imag0873.jpg
Old Jan 29, 2014 | 09:31 PM
  #57
SuperSport's Avatar
It looks like your brush housing is leaning at a good angle. That's the part in Green. And the plate that it connects to is probably melted, or broken. That's in Red.
I don't know if you can get creative and fix that, or maybe you might be looking for a new motor. There was a thread on here that talked about changing out the motor for a more common GM one, or something like that. I'd search for that and see if it's cost effective to go that route.
Personally, I'd see if I could fix that plate, but it looks pretty buggered up.
Attached Thumbnails A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation-brushes.jpg
Old Jan 30, 2014 | 09:26 AM
  #58
jalodge's Avatar
I looked at it a little more closely and realized the brushes are broken off on that side as well. It looks I will be getting a new motor.
Old Jan 30, 2014 | 09:31 AM
  #59
Charlie_V's Avatar
A warning. I followed advice on a GM blower, got the exact model suggested, and when I took mine out the GM one didn't come close. Luckily my problem was just leaves in the cage so I took the GM one back. I think it was about 80 dollars (new).
When I really do have to replace, I'll pull mine and take it to the parts place to compare them. Suggest you do the same.
Old Jan 30, 2014 | 10:41 AM
  #60
jalodge's Avatar
I found one for $35 at a local salvage yard.
