A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation
Old Jan 30, 2014 | 11:33 AM
  #61
SuperSport's Avatar
Junk yard might be a good option. Just be sure to clean and oil before installing so you don't have to go right back in to quiet it down.
Old Feb 10, 2014 | 04:22 PM
  #62
captain203's Avatar
well just finished the re and re and clean and lube on my heater fan. Couldn't take the squealing anymore. Works great now and was a fairly easy job.
Old Feb 10, 2014 | 08:25 PM
  #63
pauldavidanthony's Avatar
Thank you thank you so much for this post.
My fan was noisy and then my fan blower regulator went bad. I purchased a new one and reinstalled it BEFORE reading this post and it lasted for a week before blowing the replacement (a painful $200 lesson). I then purchased ANOTHER regulator and followed the steps for removal, cleaning, lube and re-install of the fan and (knock on wood)...so far it is working great.
Thanks again.
Paul
Old Feb 10, 2014 | 08:42 PM
  #64
SuperSport's Avatar
Thanks again.
Paul
Glad to hear it, hopefully that was the cause of the strain and overheating. Just an FYI, there's also a post somewhere talking about a bad connection on the fuse block, if I remember correctly. That could also cause overheating of the wires.
And, for what it's worth, my fan is still silent since the original post. That blows me away!
Old Feb 11, 2014 | 08:41 AM
  #65
Charlie_V's Avatar
Originally Posted by SuperSport
Thank you, and I highly suggest this maintenance. It will save you $$$ in the long run. Even just having debri in there will cause the bearings to wear faster since the fan will be out of balance. Also, moisture accumulates there due to hot and cold changes, so the bearings suffer with that too and the oil will help prevent rusting.That's a good idea. I still have not replaced my plenum filter. I need to get on it. And for those who don't know what I'm talking about, here are graphics to show what I mean.
I'm glad you posted that. My plenum air filter has disappeared and the plastic part that covers the bottom of the glass is broken in places. Do you recall what that part is called?
Old Feb 11, 2014 | 09:35 AM
  #66
SuperSport's Avatar
This?
1999-2004 Discovery II Center Air Intake Assembly - Cowl Panel
Old Dec 12, 2014 | 01:18 AM
  #67
joshrave's Avatar
Awesome write up! I will attempt this project this weekend to hopefully cure the rattling motor! Thanks again
Old Dec 12, 2014 | 09:43 AM
  #68
SuperSport's Avatar
Good luck! It kept my fan quiet until I sold it over a year later. I haven't heard from new owner yet, so assuming it's still quiet.
Old Dec 12, 2014 | 10:25 AM
  #69
matt3502's Avatar
Outstanding write up! As soon as it warms up here in the NE I'm going to have a go at this!
Old Dec 13, 2014 | 08:16 AM
  #70
Charlie_V's Avatar
Very helpful thread. Doing mine today. The intermittent squeaking is a pain.
