a/c hot from pass vents
The freon level has no bearing on the balance of cold air coming from the vents. When one side is warmer then the other there is a problem and it should be checked.
You might read up in the owners manual on how to perform an A/C diag. test, run it and get back to us with the codes. When you do the test, make sure you are outside, in the sun light and the A/C has been running for a couple of minutes.
Mike
Mike
leowiz
Dec 28, 2012 07:53 AM
