a/c hot from pass vents
Old Aug 14, 2006 | 01:49 PM
PAXPAY's Avatar
Default a/c hot from pass vents
The air that comes out of the pass side vents will not get as cold as the air on the drivers side vents, I have a 2001 disco II
Old Aug 15, 2006 | 04:02 AM
bphiggins's Avatar
3rd Gear
Default RE: a/c hot from pass vents
I had the same problem on my 01. Just topped off the refrigerant in the a/c system and its been good as new.
Old Aug 15, 2006 | 11:24 AM
The freon level has no bearing on the balance of cold air coming from the vents. When one side is warmer then the other there is a problem and it should be checked.
You might read up in the owners manual on how to perform an A/C diag. test, run it and get back to us with the codes. When you do the test, make sure you are outside, in the sun light and the A/C has been running for a couple of minutes.
Mike
Old Aug 16, 2006 | 12:26 AM
Bait's Avatar
ORIGINAL: bphiggins
You got it! Low charge causes this.
Bsnow
Jan 27, 2012 10:48 PM
Miwo
May 4, 2011 08:40 AM
DonRW2007
Apr 4, 2011 08:38 PM
Eak69
Apr 4, 2010 11:52 AM
