A/C not engaging
If the one can gets the compressor going, cool. But it may be short lived depending on the size of the leak. Once the leak has been repaired, it is strongly advised to replace the accumulator/receiver drier (the material inside will absorb moisture from the environment) then have the system vacuum tested and filled to the proper capacity.
great advice....
