A/C overheat at idle only
Old Jul 31, 2019 | 02:39 AM
  #51
JUKE179r's Avatar
Originally Posted by Best4x4
... On my 02 Kalahari with the 180F Britpart Thermostat, 620-112 fan blade, and Hayden 2991 fan clutch I started off at 198F, then it went to 200F where it sat for a good 10min, then it went to 204F and once again sat there for about 5min. Then it hit 206F and stopped going up. This is with the HVAC on LO/LO, recirculate, and max blower. My stock Bosch 130amp Alternator was sitting at 13.5v as well with all efans on.
This is my exact same setup with Zerex G-05 coolant.
On the hottest day last week (35C/95F) and while sitting at a roundabout, I was cringing while watching my temps max out at 206 degrees on my iPod with UltraGauge Blue setup. I have an alarm set on my UltraGauge app to notify me when the temps rise above 205 and it did notify me.
Old Aug 2, 2019 | 07:43 PM
  #52
CollieRover's Avatar
@Discox7 Sorry for the delay, I finally remembered my temp gun today.
After a good long commute picking up the little guy. The A/C Compressor temp was 156 directly behind the Pulley, and 138 further back.
Ambient temp was 86, A/C set to 73 blowing cold, coolant temp hit 206 in heavy traffic, but was around 197 202 most of the way.
Hope that helps.
Old Aug 2, 2019 | 07:48 PM
  #53
Discox7's Avatar
Thanks for getting back with me and that is definitely alot cooler than my compressor. Time for a new one. I’ll let you know if that has been my issue. Thanks again
Old Aug 2, 2019 | 09:08 PM
  #54
I hope that solves it for you. Maybe have the system cleaned and checked for blockage If possible?
You can just swap the pulley, and bearing, but I would not think that would make the compressor hot.
thatbaldguy
Nov 26, 2016 10:27 PM
etsZac
Dec 12, 2013 05:36 PM
grandkodiak
Mar 22, 2013 07:57 PM
mossmanxjt
Nov 11, 2012 06:38 AM
bballjames
May 31, 2012 09:29 AM
