A/C question on a 98 4.0 disco 1
Old Jul 31, 2007 | 06:39 PM
indys2k's Avatar
Default A/C question on a 98 4.0 disco 1
Ive decided to take the plunge and purchase my first land rover. It is a 98 discovery I LSE with 107,000 miles. I took it out and drove it yesterday, was a good test drive. Everything seemed to work exept the A/C. When I got back I asked the guy about it. He said he took it to his mechanic and his guy connected the compressor directly to the battery to test it and the A/C worked fine then, then put it back to normal wiring routing. Is there something between the connection of the A/C compressor and the power source that would cause it not to come on? A/C relay maybe or is that to easy.
Other thing I ran into was that when I first started the truck the rear windows would not roll down. Once the truck ran for about 5 min. I tried again and they worked fine for the rest of the drive. Is this a common issue? Thanks in advance, I will pick this truck up tomorrow and will get some pictures taken of it.
Old Jul 31, 2007 | 08:43 PM
Landzu's Avatar
Default RE: A/C question on a 98 4.0 disco 1
The AC sounds like a fuse or a relay, start there.
Make sure the electric fans come on with the ac.
The rearwindows yes its normal a easy fix,
there was a link about 3 weeks ago that has everything lined out
to fix it.
Old Aug 1, 2007 | 06:22 AM
indys2k's Avatar
good to hear, im picking the truck up later and will try and get these issues sorted out quickly. Thanks
Old Aug 2, 2007 | 12:19 PM
The a/c is controlled by the ECU, if the freon is low, it won't start, if the a/c pressure swith is bad it won't start.
Could also be a bad control unit.
As for your brakes, that is long and complecated and may not be an expensive repair.
Send me your tele number and a good time for me to call you and we can go over all of this.
Mike
colemtd
Mar 30, 2019 08:57 PM
me 2
Aug 9, 2014 05:44 PM
