A/C radiator fan seized
Old Oct 3, 2020 | 02:39 PM
Brandon318's Avatar
Default A/C radiator fan seized
Was driving with he A/C on, uphill, on a 110 degree day and noticed my temps reached 225. Very odd considering the 180 degree thermostat keeps temps around 188-194. Just checked and found what I suspected to be the culprit: blown fuse for the A\C fan and upon inspecting the fan, it’s totally seized up. How the heck does this happen? And is it worth/possible trying to repair or should I just get a new fan?
Old Oct 3, 2020 | 03:36 PM
rhyslegge's Avatar
Used fans are cheap and plentiful, my opinion is to get a used one from a reputable breaker.
Rhys L.
Old Oct 3, 2020 | 03:41 PM
Brandon318's Avatar
Ended up going this route... will report back... https://www.autozone.com/cooling-hea...128/574625_0_0
Old Oct 3, 2020 | 03:51 PM
arains44's Avatar
@Brandon318 I replaced mine a few months ago and just bought the motor instead of the assembly. It was a little DIY but the motor was $30 instead of $120+ for the new motor.
Old Oct 3, 2020 | 06:48 PM
HunterdonCounty's Avatar
I did the motor replacement only too. You can even manage the job without fully removing the grille.
Top right bolt is a bear to reach hidden behind hood latch assembly.
Managed to find a 5/16 (8mm) ratcheting wrench. Saved my sanity.
Good luck.
Dramatic improvement in my AC cooling power post project.
Nicholas Paesler
Sep 20, 2020 10:25 PM
roverwoody
Feb 9, 2016 07:29 AM
N.United
Sep 17, 2014 09:04 AM
sickws6
Dec 8, 2011 04:52 AM
BoHuang
Dec 5, 2011 08:49 PM
