A/C system unusual symptoms
Old Jan 19, 2016 | 03:25 AM
joe black's Avatar
Default A/C system unusual symptoms
Hi all,
i have a problem and nobody knows the answer. It is Discovery 2 from 2003
A/C works perfect, no error codes. Put in on AUTO/ECON and the right side blows harder then the driver side but same temperature, not colder or warmer.
Put the sustem on direct blow, everything goes perfect. I can not understand where the problem is. In winter is the situation not so good, due to the fact that on long drives on AUTO the right side window is clean and the driver side is foggy.
thank you for any advice
Old Jan 19, 2016 | 10:27 AM
abran's Avatar
Originally Posted by joe black
Hi all,
My mechanic solved the problem in a customers rover by changing the interior fuse box.
Search "fuse box AC problems", you should find some info.
Old Jan 19, 2016 | 12:31 PM
joe black's Avatar
thanks for the info but i checked everything, nobody had this problem.
cold or warm, passenger side blows stronger then drivers side.
there is a lot talk about fuse box but i do not think there's my problem
Old Jan 19, 2016 | 01:01 PM
abran's Avatar
I don't know how to properly diagnose the problem, but know that your exact symptoms were remedied by changing the inteterior fuse box.
Old Jan 19, 2016 | 02:29 PM
number9's Avatar
Does that mean manual control of blower speed or what? Who were the nobodies and how many?
Since speaking of side windows sounds like less flow out of face level vents on the LH?
Old Jan 20, 2016 | 12:53 AM
joe black's Avatar
nobodies are the mechanics for the LR dealership.
correct, it is less flow out of face level vents on the LH.
i do not know if i should change directly the fuse box and throwing 150 EUR on the window with out checking every possibilty
Old Jan 20, 2016 | 01:27 AM
abran's Avatar
eBay has them for a lot cheaper. I could also sell you one at a competitive price. But it's always wise to diagnose before throwing parts at the problem. Good luck
Old Jan 20, 2016 | 02:56 AM
number9's Avatar
What is direct blow?
Old Jan 20, 2016 | 03:37 AM
joe black's Avatar
in direct blow works all perfect and here i mean when i move form auto to manual and set the blower on face ventilation
Old Jan 20, 2016 | 12:55 PM
number9's Avatar
Joe Black, direct blow explanation understood. I'm with you and don't comprehend how changing a fuse box would help. I waded through the description/operation in both Workshop and Electrical manual after viewing the wiring diagram. When time is available will check it out again in an attempt to see what may change during direct blow. Top of my head would think drivers side vent blending may be at fault but how to fix?
