A/C system unusual symptoms
Old Jan 20, 2016 | 10:22 PM
number9's Avatar
Have you done a diagnostic check for codes yourself. If you get any it might help to troubleshoot. If not suggest you use manual controls during the winter on long drives. Maybe one day you'll find a technician who can repair it. Drive safe.
Old Jan 21, 2016 | 01:48 AM
joe black's Avatar
thanks for the help. i have also some ideea, due to the fact that we have dual zone clima, is it possible that the in car sensor have some kind of error and register wrong to the left and right temp ? is only an iddea
Old Jan 21, 2016 | 02:51 AM
number9's Avatar
Originally Posted by joe black
thanks for the help. i have also some ideea due to the fact that we have dual zone clima, is it possible that the in car sensor have some kind of error and register wrong to the left and right temp ? is only an iddea
Good you also have some idea. Have you tried decreasing the temp on LH side to get more flow from the face vents? Are the LH & RH temps set differently? Looking at the wiring I don't think temp sensors control the RH & LH. The control panel ATC does that just by upping or lowering one or other side. That is why asking if you did the system test on the panel which I made a copy of but forgot to attach.
File Type: pdf
Old Jan 21, 2016 | 03:48 AM
joe black's Avatar
yes i made the test and i have no errors. i did not check what happens if i decreasing the temp on LH side, i will try. But if i have more blow in this situation for sure i will have also colder air then on RH, witch also is not in my interest. If the sensor is not the problem and for sure it is nothing that is the stopping the air because on manuel it works i see it only an electrical problem that comands to blow slower on the LH
Old Jan 21, 2016 | 07:49 PM
number9's Avatar
But if i have more blow in this situation for sure i will have also colder air then on RH...................................i see it only an electrical problem that comands to blow slower on the LH
It doesn't blow slower on LH. More flow is going to the floor and less to face. The LH blending servo motor & it's commands controls the blending.
Try having different LH and RH temp settings that might get the flow you want. If that doesn't work keep warmer clothing available until repaired.
Old Jan 22, 2016 | 04:40 AM
joe black's Avatar
the hole ideea is to repair what ? if someone can tell me what to fix, i will gladly do it
Old Jan 22, 2016 | 05:49 AM
number9's Avatar
what ?
I have given an opinion after spending my time looking over the diagrams and description/operation to try to help you out.
Hire an expert or go with the suggestion in the first reply if you would like.
route66lives
Apr 26, 2017 04:00 PM
DonRW2007
Sep 26, 2012 01:55 PM
Cowtown1411
May 1, 2012 09:37 PM
Cnydisco99
Feb 24, 2011 11:03 AM
kinden
Oct 16, 2009 02:30 AM
