A/C Vent temps.
Old Aug 11, 2020 | 07:15 PM
The_OGCJR's Avatar
Default A/C Vent temps.
Passenger side wasn’t cold so I got the a/c recharged at a shop.
04 D2 with rear a/c
in Texas...
we were confused (I know the technician) on the Freon amount needed because the sticker says 780g and rave says 900g...so we/he put 900 in it and at idle, 100 degrees outside the shop and the driver center vent only gets to 60 degrees. 2 years ago when I did this before i seem to remember getting 48 degrees at the vent. Using a stick thermo...
so does anyone know if 60 degrees sounds right? Seems high to me.
Old Aug 11, 2020 | 07:50 PM
nashvegas's Avatar
My 2000 says 700 (w/out rear air) & 900 (w/ rear air) on the sticker underwood. I think 03/04 may have changed. Your underwood sticker on the 04 says 780 w/ rear air?
I do think 60 is a bit high. I get 55-56 on mine on a hot day which could be better and feels marginal to me.
Old Aug 11, 2020 | 07:53 PM
Extinct's Avatar
Little high, should get down to around 40's, what's your pressures?
Old Aug 11, 2020 | 09:04 PM
Best4x4's Avatar
Which vent? I don't know of a single D2 out there today especially in TX that still has a tightly sealed up HVAC blower box. All the foam has either flown out the vents, got stuck in the blower, or has fallen up inside the dash. That'll cause cool air to leak out before it ever gets to the actual vent and maybe that's why you had such a poor reading.
Old Aug 12, 2020 | 09:22 AM
The_OGCJR's Avatar
ive re-foamed all vents. I have NOT refoamed above the blower box though.
I’ll get back to y’all on pressures. Can’t remember. I’ll ask him
Old Aug 12, 2020 | 11:11 AM
The_OGCJR's Avatar
the 90psi on low AND high side. I think high sode
should be around 120?
Old Aug 12, 2020 | 12:02 PM
DodyDisco's Avatar
Gotta check pressures with the system running/compressor cycling. Ac on coldest setting, max fan and not on recirculate is best. 90 would be extremely high for the low side and super low for the high side.
Making an assumption the system was off with the 90/90 numbers.
Ambient temps will affect your pressures to an extent as well. theirs quite a few r134a low/high pressure guides if you google a bit.
Old Aug 12, 2020 | 12:06 PM
boston4's Avatar
Sounds like this is the static pressure in the system (it equalizes while the compressor is not running). The pressures are ambient temperature-dependent but you need to get readings while the compressor is running.
https://rechargeac.com/how-to/ac-system-pressure-chart
DiscoNickBK
Oct 5, 2018 04:05 PM
za105
Jul 6, 2016 10:59 PM
cappedup
Oct 6, 2014 12:17 PM
etsZac
Dec 12, 2013 05:36 PM
Rover Dawg
Jan 16, 2013 08:29 PM
