Caliper Bolts... Locktite or Anti Sieze??
Old Jul 13, 2009 | 09:51 AM
llPANCHOll's Avatar
Default Caliper Bolts... Locktite or Anti Sieze??
In the middle of a brake rebuild.
I have seen diffrent people state diffrent things...
Have not found any notation in the manual regarding this..
Old Jul 13, 2009 | 10:24 AM
I have never used either, but if I were to I think I would go with one of the more light duty locktites, allowing you to remove them when needed.
Don't forget the sound deadening spray and a 3 pint brake flush/bleed.
Old Jul 13, 2009 | 10:46 AM
Malave99's Avatar
I used anti seize. After having such a hard time getting the caliper bolts off, I figured the next time around would be alot easier. Then I just torqued everything down to spec.
Old Jul 13, 2009 | 02:45 PM
lipadj46's Avatar
At the most use the purple locktite with the proper torque setting. I broke a craftsman ratchet getting mine off the first time.
Old Jul 13, 2009 | 03:32 PM
04BluDisco's Avatar
Mike, Do you need to bleed the brakes after you put on new calipers/rotors? Or is it just a good time to do it, as you should every 2 years...
(just curious as I bled the brakes 6 months ago, and recently replaced pads and rotors... )
Old Jul 13, 2009 | 04:25 PM
smokeyrabbit's Avatar
If you put on new calipers you'll need to flush/bleed the system. If you change the rotors without introducing air into the brake lines you technically wouldn't need to bleed the brakes, but you may want to flush the fluid depending on when it was last done.
Old Jul 14, 2009 | 04:33 AM
antichrist's Avatar
The shop manual calls for loctite 270, and that's what I've always used.
expedio2005
Jan 22, 2013 03:43 PM
TRIARII
Dec 17, 2012 07:51 AM
oc_nd_fan
Dec 14, 2009 11:34 AM
arives350
Aug 13, 2009 05:02 AM
