Caliper Replacement/Brake Bleed Question
Good one drowssap, I've learned something from this today. I agree clamping even a rubber stock hose can crack the nylon mesh reinforcement. I never knew/realised holding down the brake pedal cut off the reservoir fluid and that's going to be very useful when I rebuild my calipers. Thanks for the info.
DSCVRY, if you do this, could you take some pics of what bolts exactly need to come off for caliper removal? I was going to do this, but I had a hard time losening the caliper bracket, but perhaps it seems I can take the caliper off just with the guides. (Ive seen youtube videos to that effect on other makes).
Offroadfrance: The loctite might explain why I could not get the stupid bolts off last time I tried even with PB Blaster. An trick to this? With the car on jack stands, I did not have clearance for a breaker bar and due to the steering linkage, I could not get a wrench in such a position where I could hammer on it. I have a smaller air compressor, perhaps an impact gun might do the trick?
If changing rotors you defo have to remove the caliper brackets also, I've had trouble with those 12 point bolts and you ideally need 12 point HD impact sockets to shift them as often they break standard sockets even quality ones.
potxoli (12-01-2014)
zracin
07-31-2011 03:43 PM
