cam fault
Old Jan 15, 2012 | 10:58 PM
parksy's Avatar
Default cam fault
can anyone out there tell me what a cam fault is and would this cause m and s lights to come on . any help ta
Old Jan 16, 2012 | 08:04 AM
Perhaps you are speaking of a CAN fault which is a communication link in the vehicle. In the workshop manual under automatic gearbox you will find a table of all codes from the tranny ECU.
Like :
P1841
(16)
* CAN bus fault Maintains current gear in low range, limp
home mode in high range. Shift pressure to
maximum, harsh gear shifts/engagement.
Mil light on M&S lights on
Old Jan 16, 2012 | 11:04 PM
parksy's Avatar
would this also be caussed if something like an aftermarket cd system was installed
Old Jan 16, 2012 | 11:23 PM
The CAN buss connects some of the computer modules to each other, so a wire could have gotten pulled the wrong way. Pins 16 and 44 on the connector from the transmision ECU, which may be under left hand seat. May be a twisted pair wire. See attached. CAN is controller area network, links main ECU and transmission ECU.
File Type: pdf
File Type: pdf
06Range
May 8, 2013 09:01 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
anhernandez
Aug 18, 2009 12:47 AM
