Cam Shaft Broken. What could be the cause?
Old Jun 21, 2013 | 04:33 AM
Rabih A. Yaghi's Avatar
Default Cam Shaft Broken. What could be the cause?
I have a disco 2 2002(w/O secondary Air) 150k. My engine(new heads) stalled the other day . i tried to pullover only to hear an explosion noise and my oil all over the place. I looked under and the short block had a 3 inch hole in it right under cyl 6. I have had a loss of compression in cylinder 6 for a few weeks now and i thought it was bad piston rings. i started taking the engine part today and after removing the exhaust manifold gasket i saw that my Cam shaft is missing a piece and broken between Cyl 7 & 6. my rocker arm(driver side) had the rocker broken at cyl 7 and the 2 of the lifters on that cylinder we sunk into the engine. My question is what could of caused a cam shaft to break that way. i have not pulled the block out to see what kind of damage i have around cyl 6 where the hole is.
PS: i have replaced the lifters with refurbed ones that compressed very nicely when i put them in a few weeks ago but now when i took them out they were all locked as they if they are full of air, is that normal or something is wrong with lifters as well?
Sorry for the lengthy post, all your help is appreciated
Old Jun 21, 2013 | 09:33 AM
Dan7's Avatar
Stuck lifter = bent pushrod = snapped cam?
potatoes
Feb 19, 2014 10:22 AM
expedio2005
Jan 11, 2014 07:18 PM
bradysminus1
Sep 13, 2013 03:29 PM
Rabih A. Yaghi
Jun 22, 2013 02:48 PM
Vertigo RT
Sep 6, 2010 11:44 AM
