Cam Shaft Broken, What Happened?
Old Jun 21, 2013 | 12:00 PM
Rabih A. Yaghi's Avatar
Ok perfect! I thought I did something wrong with the lifters. When I took them out I couldn't push them down at all. Out of curiosity how do they release the pressure? Or are they always pressurized. And yes I will only use the block. I am gonna take SAI heads to the shop to change seals and clean valves and resell. Is it true that u can use those on a non SAI if u plug them?
Thanks again
Old Jun 21, 2013 | 01:07 PM
RoverMasterTech's Avatar
The piston was fatigued from miles, When you tightened up the top end, the rod disconnected itself from the piston,(probably cracked around wrist pin) punched up through the cam, then punched a hole in the block, seen it before. Nothing you could do, it was just old and worn out. Has nothing to do with the lifters or the cam.
Old Jun 21, 2013 | 01:19 PM
Chris that makes a whole lot of sense and seems like a very probable cause. Because all of the damage was around cyl 6 that had no compression which I am starting to believe had to do with the piston rod. I did the head job thinking they were leaking. But if the piston rod was loose then it was causing the bad compression then eventually it got loose and broke cam shaft and threw a hole in the bottom.
I am working on rebuilding a new block, do u know where I can get the set of rings and gaskets etc... For it
Thanks again that was very helpful
Old Jun 21, 2013 | 05:44 PM
99Discovery's Avatar
Chris,
Do you see a lot of fatigue failures and destruction at 150k? This failure is interesting to me as my Rover has 99k on it right now. I was under the impression that if the weak block castings held and my cooling system/maintenance was kept in check, I could get 200k out of the motor.
If this is an unlucky and fairly uncommon problem then that is one thing, but if Rover V8s like to throw rods around 150k, I might have to rethink my dreams of modding the Disco and just enjoy it as is, nearly stock with 2" OME lift, and save the money for something else when the 4.0 eventually gives up the ghost..
Old Jun 21, 2013 | 11:42 PM
msn619's Avatar
I had or almost similar happened to me on my 4ag motor, in my case my exhaust cams broke i figured the torque spec of the camshaft bolts was not all even. good thing is it sounds like you know your way around a disco so not worried hope you get your disco back in the road.
Old Jun 22, 2013 | 08:46 AM
Originally Posted by Rabih A. Yaghi
i opened the lifter and put oil in it and reclosed it. was that the proper way to do it?
when the lifter were installed they were soft enough for me to push them down with my finger.
I am wondering if the lifter had anything to do with it since the problem i have had with cylinder 6 not building up pressure existed before i did the head and lifter job.
Did you not read my information regarding never installing used lifters on an old Rover cam??????????????
I see you are hanging onto another set of used ones which really concerns me.
Old Jun 22, 2013 | 09:36 AM
DiscoRover007's Avatar
Originally Posted by 99Discovery
Chris,
Don't freak out. Just keep the cooling system in check and make sure it has oil in it. She'll go.
Old Jun 22, 2013 | 01:51 PM
So Mike, what do you recommend. If i can't use new ones? also could you please give me some info concerning remanufacturing and installinganother block?
thank You
Old Jun 22, 2013 | 02:48 PM
Default Update
The block is out. As you will see in the pictures below, Cyl 6 piston rod broke and tore everything apart.
but what has me wondering is I did find a freeze plug in the block that was all bent out of shape. i am not sure were it came from but now i am wondering if it had anything to do with the loss of compression and if it was the cause for everything jamming and causing the damage, or did the plug fall after the rod broke and tore the block.
the block i bought from the yard is int eh machine shop, all comments and suggestions are appreciated.
Thank you, you guys are awesome.
[IMG] Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting [/IMG]
expedio2005
Jan 11, 2014 07:18 PM
bradysminus1
Sep 13, 2013 03:29 PM
Rabih A. Yaghi
Jun 21, 2013 09:33 AM
Greenagain
Jan 30, 2008 08:40 PM
